Rolling dice
Rolling dice
A quick rolling dice file I put together. I haven't had the chance to cut,bend and weld this up yet, Hope to this weekend.
- larrycameron44
Re: Rolling dice
Cool thanks, but I think you need to swap the holes around as all opposite numbers on a dice should equal 7HellfireOffroad wrote:A quick rolling dice file I put together. I haven't had the chance to cut,bend and weld this up yet, Hope to this weekend.
Larry NZ
Re: Rolling dice
It won't open in Autocad 2011
Re: Rolling dice
Will this dxf open, it's the same as the other one, only imported into pcam and exported as dxf again.pete4477 wrote:It won't open in Autocad 2011
Jason Lyon
PlasmaCAM DHC2
Advanced DesignEdge
Hypertherm Powermax 1000
Everlast PowerMTS 251si
Torturing metal since 2014
PlasmaCAM DHC2
Advanced DesignEdge
- HammerDownJustin
Re: Rolling dice
Opens in Corel just fine
Miller 251 Mig
Miller 251 Mig
Re: Rolling dice
So you would move 2 up and the 6 down??larrycameron44 wrote:Cool thanks, but I think you need to swap the holes around as all opposite numbers on a dice should equal 7
Larry NZ
Both files opened in autocad13
1250 hypertherm
4 X 8 Precision Plasma
CandCnC electronics
CandCnC electronics
Re: Rolling dice
Here is my version
Re: Rolling dice
its set up to be easy to bend
Re: Rolling dice
Pic of last posted:
- 1/2 Star Elite Contributing Member
Re: Rolling dice
What thickness steel is everyone using for the dice?
Re: Rolling dice
These are cool! Thanks for digging up this thread, I have yet to see this one! Happy Thanksgiving!!
Re: Rolling dice
thanks
