Texas A&M Fire pit
Texas A&M Fire pit
Here is my first post on the forum of a file for a Texas A&M fire pit that I am making for a guy. Thought I would share, and feel free to change up the art work inside. 30" wide with 7" tall sides. Haven't started yet, but will add some pictures as I go.
- GoingCustom
Re: Texas A&M Fire pit
Thanks for posting Looking forward to seeing finished pics
Scheub wrote:Here is my first post on the forum of a file for a Texas A&M fire pit that I am making for a guy. Thought I would share, and feel free to change up the art work inside. 30" wide with 7" tall sides. Haven't started yet, but will add some pictures as I go.
Here are the updated dxf files and a finished fire pit other than some high temp paint. Hope someone could use it
dxf files
- Zippo
Thanks for posting.
Looks really neat, I like the footrest idea. Looks to be about 3/16" or is that 1/4"?
Jason Lyon
PlasmaCAM DHC2
Advanced DesignEdge
Hypertherm Powermax 1000
Everlast PowerMTS 251si
Torturing metal since 2014
PlasmaCAM DHC2
Advanced DesignEdge
It is 3/16"jasonl wrote:Looks really neat, I like the footrest idea. Looks to be about 3/16" or is that 1/4"?
This is one of the better ones I've seen great job. Thanks for the post...... How much steel did you use???
Thanks cbass, I used about 2/3 of a sheet of 3/16" plate. You should be able to cut it out using closer to 1/2 a sheet, as I had some user errors while cutting it out, and had to move around.cbassjr wrote:This is one of the better ones I've seen great job. Thanks for the post...... How much steel did you use???
If I may ask about how much is the asking price for a fire pit like that?
$200 for customized fire pit w/ paintCOLT wrote:If I may ask about how much is the asking price for a fire pit like that?
$150 for plain pit w/ paint
Getting ready to cut one of these for a customer. Are you using 1:1 or inches for sizing when importing into sheetcam. Looking at DXF it appears everything is drawn to scale and would be pretty easy to scale up using sizing to a 48" pit. Have you built a bigger one by scaling up???
- HammerDownJustin
Not to bad..about $75 in material after steel and paint. Thank you for posting.
Miller 251 Mig
Miller 251 Mig
I import into sheetcam using inches. Everything should be to scale, so I don't see why it wouldn't work scaling it up to 48". I haven't built any by scaling up. I typically end up just redrawing the pits based on customers' specifications.cbassjr wrote:Getting ready to cut one of these for a customer. Are you using 1:1 or inches for sizing when importing into sheetcam. Looking at DXF it appears everything is drawn to scale and would be pretty easy to scale up using sizing to a 48" pit. Have you built a bigger one by scaling up???
I have a few newer pits that I will post today that you may like as well. They used square tubing legs, which I think look a little better than the cutting the plate legs, and square tubing for the boot rail.
- MetalheadRK
Can't believe I found this! Working with one of the Aggie Mom groups and we were just talking about this 3 or 4 days ago. Thank you!!!!!
4x4 PlasmaCam
Hypertherm 45
Eastwood 175 MIG welder
Hypertherm 45
thank you
Thanks for the file. Cut out flawlessley!
Gig'Em! Thank you for sharing!
- kchoghead
Thanks for the share!
Good Job Thanks for the share
