Custom firepit
Custom firepit
4 foot wide fire pit, sits about 2 feet tall and slopes down 6 inches on each side.
1/4" steel, used power break to bend at every corner
High temp powdercoat finish
Re: Custom firepit
Nice Job. Thanks for the share
Tracker CNC Nitro
Miller Matic 251
Miller Shop Mate 350
FEAR NOT!!!
Michael Garriott
Miller Matic 251
FEAR NOT!!!
Michael Garriott
Re: Custom firepit
I like the the look, Thanks for sharing
Re: Custom firepit
Thanks, looks good
Precision Plasma Patriot 4X8, water table, Price THC, UC 400ETH, Floating head
Hypertherm 45XP - Machine torch
UCCNC, Sheetcam, Inkscape/Corel X5
Re: Custom firepit
great share ..thank you
Re: Custom firepit
Very nice and very unique. Thanks for sharing
Re: Custom firepit
Love the simple look to it. Sometimes and IMHO very often....LESS IS MORE!
Joe Peterson
4'x8' TM 2 Water Table
TD A80
Flashcut CAD/CAM/CNC
Eastwood QST 30/60 Scroll Comp
ESAB Rebel 215ic
TD A80
ESAB Rebel 215ic
Re: Custom firepit
I'm wanting to build one like this but having trouble with the sides. We are not able to bend and have to cut and weld. Any help would be great.
Re: Custom firepit
You can cut slots along the bend lines to facilitate bending by hand. You can finish weld slots (or not) after you have the entire assembly aligned and tack welded together.
Re: Custom firepit
Wow. Thank you very much!
Re: Custom firepit
I would suggest cutting a sample part to see how easy it bends, and how wide the gap is after bending to the correct angle. You may need to adjust the width of the cuts, and the width of the tabs left for bending after trying out your sample. I did something similar with a fire pit bottom path last year from 11 ga. steel and it worked out fine. You can see the photos from the link below. Admittedly this was a small part, and thinner material, but the basic concept is still the same. I would question the need for 1/4" steel plate for a fire pit, and suggest that 11 ga. (1/8") should be more than adequate for many years to come.
https://photos.app.goo.gl/kHnoZ5jKn2cvgus37
Re: Custom firepit
Thanks. I believe that 10-11 ga is plenty as well. Thanks for all the input. Im ready to get to it now. Actually pretty excited about going to work tomorrow now haha
Re: Custom firepit
thank you so much
Re: Custom firepit
Thank you for the share, this is awesome!
