It is currently Wed Oct 17, 2018 11:13 pm
Corner Weld Jigs
DXF Art Sharing Forum is for sharing dxf, plt, or any other vector file for plasma cutting. Browse what others have posted or post some DXF art files of your own.
vanhulagen
Corner Weld Jigs
Postby vanhulagen » Sun Jan 14, 2018 4:55 am
corner welding jigs i drew it for 3/16
corner1.dxf
corner2.dxf
corner3.dxf
oldironrep
Re: corner weld jigs
Postby oldironrep » Sun Jan 14, 2018 8:16 am
Thanks. Any good welders on here have any tips on welding sequence so it doesn't twist like a pretzel? My brain usually tells me the exact opposite way to weld it.
Scratch
Postby Scratch » Sun Jan 14, 2018 9:05 am
oldironrep wrote:Thanks. Any good welders on here have any tips on welding sequence so it doesn't twist like a pretzel? My brain usually tells me the exact opposite way to weld it.
Here's a good video on a build of a similar one.
https://m.youtube.com/watch?v=_-JlHM_EWf4
Bradley
Postby Bradley » Sun Jan 14, 2018 4:36 pm
Maybe tig weld just the outside tab inserts, then lay a piece of one inch over it and clamp it down till it cools, it shouldnt twist that bad, if you dont have any one inch, use some aluminum 1/4 plus thick and clamp it to a table, it will draw the heat out quicker.
vanhulagen
Postby vanhulagen » Sun Jan 14, 2018 10:12 pm
Bradley wrote:Maybe tig weld just the outside tab inserts, then lay a piece of one inch over it and clamp it down till it cools, it shouldnt twist that bad, if you dont have any one inch, use some aluminum 1/4 plus thick and clamp it to a table, it will draw the heat out quicker.
thats what i wasgoing to do just weld the outside off the tabs and maybe tac the ends
vanhulagen
Postby vanhulagen » Mon Jan 15, 2018 2:35 am
hears in adjustable one
cornerajust1.dxf
cornerajust2.dxf
cornerajust3.dxf
motoguy
Postby motoguy » Mon Jan 15, 2018 8:04 am
These should come in handy. Thanks!
TimP
Re: Corner Weld Jigs
Postby TimP » Mon Jan 15, 2018 12:33 pm
Thank you for the share!
A nice addition to the welding table.
Tim
techno
Postby techno » Tue Jan 16, 2018 9:20 am
Thanks for sharing.
BILLETMAN
Postby BILLETMAN » Wed Jan 31, 2018 3:47 pm
thanks guys great ideas
james.davis
Postby james.davis » Wed Jan 31, 2018 4:25 pm
look up back step welding
Jim
Capstone
Postby Capstone » Wed Jan 31, 2018 5:37 pm
I made up a pair of these... thanks for the share. check out my Instagram for a pic.
Phil
It's all relative...
CNC Metal Design
Instagram CNC Metal Design
JD Squared 4x8
HT PM45, Miller 251 MIG
steel 35
Postby steel 35 » Wed Jan 31, 2018 7:29 pm
Shaweet
PPL HDG 4X8
Hyp 65 duramax's
C&CNC 620-5 Ethernet
Corel X7 Student NO DXF!
steel 35
Postby steel 35 » Wed Jan 31, 2018 7:32 pm
Except know I need a scribe!
PPL HDG 4X8
Hyp 65 duramax's
fasteddie
Postby fasteddie » Sat Mar 10, 2018 12:17 am
Thanks, I have been wanting a set of these.
fasteddie
Postby fasteddie » Sat Mar 10, 2018 12:18 am
Thanks, Very nice.
Users browsing this forum: Bdh66, G4 PRECISION and 22 guests
