Need SheetCam Post Processor for Starfire controller
I have the Baileigh cnc plasma and I have a problem with Starfire Controller SF-2300S-QG it doesn't read the g-code from sheetcam then I need a custom post processor for the starfire controller. Can anyone help me to resolve this issue?
Re: Need SheetCam Post Processor for Starfire controller
Here is a post. To install this post, op the attachment and save the contents to to any convenient folder on your computer. Run SheetCam and go to Options->machine->post processor. Click on the 'Import post' button. Using the box that appears, navigate to your post and open it. Go back to Options->machine->post processor and make sure your post is selected.
Many thanks for your respond, I used your document but unfortunately the g code generated doesn't work correctly. Please find in attach the work generated with the Baileigh Starfire post in sheetcam and you can compare it with the correct gcode generated by starcam.
