Cut image inside of a pre-existing material shape
Post your questions or tips on SheetCam software in this topic.
Searchman
Post by Searchman » Thu Sep 20, 2018 11:09 am
Is there a way to set up Sheetcam to cut within a material shape that is not rectangle or square?
For instance round.
SegoMan DeSigns
Re: Cut image inside of a pre-existing material shape
Post by SegoMan DeSigns » Thu Sep 20, 2018 11:31 am
What I do in a cut like this is to layout the perimeter to match the existing object then insert what you want to cut out of it. Turn off the torch and do a couple of dry runs to align things. Once aligned turn on the torch and start cutting when the ID is cut pause the machine and remove the plate.
Return to “SheetCam”
