It is currently Tue Nov 13, 2018 11:54 pm
Slowing down for holes
Post your questions or tips on SheetCam software in this topic.
Rusty35
Postby Rusty35 » Fri Jun 16, 2017 6:29 pm
How does everyone slow down for holes?
I have tried using cut rules for holes but it only slows down for part of the hole on larger holes and ignores smaller holes.
motoguy
Re: Slowing down for holes
Postby motoguy » Fri Jun 16, 2017 6:43 pm
Put the holes in their own layer. Set the feedrate for that layer to your chosen slowdown rate (I usually use 50% of the regular feed rate). If you don't want to use THC (you usually don't on small holes), set the "min dist before THC) to hole to diameter x 3.2, or radius x 6.3, + your lead in/lead out distance. I usually just make it easy by selecting something like 20 inches on any holes under 2 inches. :)
Return to “SheetCam”
