troubles with sheet cam
can someone tell me why sometimes my parts cutout twice on the same cut,it looks like sheetcam is running the g-code two times for the same part. thanks dave
Re: troubles with sheet cam
More then likely you have double lines in your drawing file..
1250 hypertherm
4 X 8 Precision Plasma
CandCnC electronics
CandCnC electronics
- SeanP
Another one is when using multiple duplicate of a part you have one part on top of another, easy done.
Powermax XP45
R-Tech 210 Tig, Jasic 250 mig
Table build gallery
Table build gallery
- _Ogre
if sheetcam is laying out 2 separate cuts, it should have 2 separate layers with a cut on each layer
turn off one layer
turn off one layer
an ogre smiley how cool!
