On the sheetcam screen it will show 47 start points, when I look at the job report it will show 68.
When the file cuts it will actually do the 68 pierces. when I look closely and zoom in I can see a line that will
not have a start point but will cause the torch to pierce at that point. I cannot see anything in corel draw.
Very frustrating, any ideas on why this is happening?
Job report shows more pierces
PlasmaRoute CNC 4 x 4
Corel Draw X5
SheetCam
Baileigh 12 gauge 40 inch box brake
Corel Draw X5
SheetCam
Re: Job report shows more pierces
I have had this happen when a gap in a drawing is smaller than kerf width, so sheetcam will not run the tool through the gap. Instead, it creates another (non-numbered) pierce point, on the other side of the gap. It also will not allow me to modify the start point on this pierced area, either. In sheet cam, look for non-numbered pierce points, or gaps too small for your tool. You'll probably find your mystery pierce points.
- tnbndr
If you have multiple tools set up for a cut Sheetcam only shows the pierce numbers for the tool selected!
LDR 4x8, Scribe, DTHCIV
Hypertherm PM45, Macair Dryer
Miller 215 MultiMatic
RW 390E Slip Roll (Powered)
AutoCAD, SheetCAM, Mach 3
http://ikescreations.com
motoguy wrote:I have had this happen when a gap in a drawing is smaller than kerf width, so sheetcam will not run the tool through the gap. Instead, it creates another (non-numbered) pierce point, on the other side of the gap. It also will not allow me to modify the start point on this pierced area, either. In sheet cam, look for non-numbered pierce points, or gaps too small for your tool. You'll probably find your mystery pierce points.
Thanks, sometimes I can find them some times not.
Corel Draw X5
SheetCam
Corel Draw X5
SheetCam
