Hello,
Sheetcam updated to 7.1.8. Now when I use Run Post Processor the file is saved as .CNC file, instead of .TAP file. My Masso unit does not see .CNC files. Was working fine before update. Help please.
Run Post Processor from .TAP files to CNC files
- jmersereau
Re: Run Post Processor from .TAP files to CNC files
I also updated to 7.1.8 but still export .TAP files. Is it possible you changed something else at the same time?
Jim
Jim
PrimeWeld CUT60
Langmuir CrossFire Pro
Nothing that I know of.jmersereau wrote: ↑Mon Mar 29, 2021 8:13 pm I also updated to 7.1.8 but still export .TAP files. Is it possible you changed something else at the same time?
Jim
- jmersereau
Check in SheetCam under Options, Machine, Post Processor to see if your settings were reset on update
PrimeWeld CUT60
What post processor are you using? It could be that your post processor was updated at the same time. Some posts set the file extansion to a fixed value.
Thanks guys. It was my Post Processor. When I updated, it changed processors.
Good afternoon i am having the same problem i don't know what post processor to use
If you give info on your table/electronics a suggestion can be made as to the post processor you should use. Les has supplied many post processors with SheetCam because there are many differences in table designs and options that tables can have.
