Sheet cam closing open paths on import
- Sampson Jones
Ive cut this several times with no problems . Today upon import it tries to close open paths . I start in corel , join curves , combine , save to thumb drive . All looks good , until sheetcam import , which tries to add lines to open paths .
CandCNC electronics
Hypertherm powermax 65
Command Lineux
Super z 2
Inkscape and corel draw
CandCNC electronics
Command Lineux
Super z 2
Re: Sheet cam closing open paths on import
Have you recently updated Sheetcam?
You can see many overlapping lines and parts that are moved around. have you tried to save in a different format (DXF,SVG) and some DXF formats have different years in their titles which make a difference too.
- Sampson Jones
CandCNC electronics
Command Lineux
Super z 2
CandCNC electronics
Command Lineux
Super z 2
- Sampson Jones
Heres imported in svg instead of dxf
CandCNC electronics
Command Lineux
Super z 2
CandCNC electronics
Command Lineux
Super z 2
I just had issues yesterday making a simple square on my laptop(not connected to my table) with inkscape. Then I "save it as" to my jump drive and then walk to my barnshop and load as I always do to the table PC. Well for the life of me I could not get sheetcam to open the simple square with 4 holes, it would not open the image at all. I then went into inkscape on my table PC and thought I did not have object to path or something. Did that and saved it and went to sheetcam again. Still no good. I think my jump drive is corrupt. However ever since I updated my Command CNC to 1.2.2 I have some strange issue happening. Some of my pierce delays are gone as well.
- Sampson Jones
For the record , I'm running command cnc with sheetcamv6.1.57 and post post processor llcnc-rev.29b edited
CandCNC electronics
Command Lineux
Super z 2
CandCNC electronics
Command Lineux
Super z 2
- Sampson Jones
Ok , in corel i saved if from a cdr to a dxf , then reopened the dxf in corel and it has to open paths closed , screwed up . I wonder why corel is doing this ? And why is the circles all over the imported svg file in sheet cam ?
CandCNC electronics
Command Lineux
Super z 2
CandCNC electronics
Command Lineux
Super z 2
Saving a cdr from Corel to dxf and then opening that dxf in Corel is going to cause problems. Saving designs as a different format has the software interpreting things as best it can but its never perfect especially with dxfs.
What happens if you simply save your cdr (the original) as dxf and open in Sheetcam? Or is that what you did the first time?
- Sampson Jones
Thats what i did the first time . Thats how Ive always saved a cdr to dxf and then took it to sheetcamweldguy wrote: ↑Thu May 20, 2021 8:49 pm Saving a cdr from Corel to dxf and then opening that dxf in Corel is going to cause problems. Saving designs as a different format has the software interpreting things as best it can but its never perfect especially with dxfs.
CandCNC electronics
Command Lineux
Super z 2
CandCNC electronics
Command Lineux
Super z 2
- Sampson Jones
Apears to be a corel problem , when i do a save as it closes open paths on a combined drawing. When I do a save as on a grouped drawing it does not save any open paths ? WTF ? Been doing this along time and it just did this yesterday . Where to start ? Moving to the corel page , I guess.
CandCNC electronics
Command Lineux
Super z 2
CandCNC electronics
Command Lineux
Super z 2
Did you ever resolve this? Im experiencing same problem going from ViaCad to SheetCam.
And I do believe my sheetcam was updated, is that bad?
Post your dxf outputted from ViaCAD here and we will take a look.
Can you recommend the best way for a newb to post my file?
When you want to attach a file.image click on the Full Editor & Preview button, that will bring up a screen with an Attachments button. Click on that and you will see a add files button click on that. It will open a screen where you can add one file at a time. Now some files will need to be processed using WinRar (or another Zip file formatter ) some images will not load if they are to large also. Try resizing them with an image program.
Here it is, its pretty much a squiggly line and two circles. Sheetcam connects the ends of the squiggly line.
What is your specific problem with this file?
Are you saying that sheetcam adds an extra line here?
This is what it looks like after linking/joining. File attached below.
Exactly a you stated, when I opened the file in sheetcam it would add the additional line. I grouped the file in Viacad before exporting. But I have never used Link or Join.
Is linking/joining a cad option or sheetcam?
I will load the linked/joined file into sheetcam and see the results.
!!!UPDATE!!!
I just uploaded your file into Sheetcam and it all looked good. Thanks much for your time and patience.
I am still curious about the link/join option, and how I do it.
In case you are wondering that is a file to cut off a chainsaw bar to be used in a chainsaw winch, my buddy wore out his previous bar.
!!!UPDATE!!!
This type of problem has be talked about before here. There seems to be some slight differences between software file formats. Un- expected lines appear in SheetCam. Sometime it's a difference between DXF and SVG, sometime between the version dates of the DXF file save format. Some have used a conversion bridge software (another CAD) to pass a file through before SheetCam. I don't think we can point a finger directly one area. just one of those whoops moments. I use TurboCad for drawing some projects and it looks like lines are connected, even when I use the join polylines command and click on each line to complete the item, with the finish button. Only to find they are not connected with the next software I use. A work around is to use the fillet function (very small ) to connect the line, mainly shows in the 3-D software is use. No answer just an observation
When I open you file with Design Edge, it has some individual paths that have not yet been joined together. The zero length nodes are located at the intersections between each individual path. After linking the individual paths to join them into one continuous path, this is what it looks like. Since you do not have Design Edge, another option is to use LightBurn to accomplish this. You can purchase LightBurn for $60 and it is well worth the money. Open your dxf with LightBurn, then export as dxf and your file will be automatically linked together.44newman wrote: ↑Sat Nov 06, 2021 10:33 am Exactly a you stated, when I opened the file in sheetcam it would add the additional line. I grouped the file in Viacad before exporting. But I have never used Link or Join.
!!!UPDATE!!!
Open your dxf file with LightBurn. Export as dxf. I have opened the exported dxf with Design Edge to check it.
Here is the LightBurn download link. You can try it free for 30 days and then decide it you want to purchase it. Cost to purchase is $60.
In addition to the linking of paths, it is great for creating and editing drawing files as well. It also has a great auto trace feature (auto trace/vectorize) for converting jpeg/bitmap files to vector format and exporting in dxf or svg format.
https://lightburnsoftware.com/pages/tri ... re-you-buy
Thanks for all your help and insight guys. Thumbs up.
You are welcome! We are always happy to try to help.
