sheetcam cut speed not recognizing in mach
Hello, IM having an issue where when i put in a diffrent cut speed in sheetcam,then post process, and load it up in mach. Mach wont recognize the new cut speed. I have to maually go into g code and chage it in order for the new cut speed to be recognized... is there a glitch or something i need to fix or something in the setup that can correct this? please help.. thanks in advance
- WyoGreen
Re: sheetcam cut speed not recognizing in mach
The g-code is put out by Sheetcam, so if you are having to edit the g-code in Mach3 to change the cut speed, it sounds like the Sheetcam Post Processor is where the problem is. You could look at the G-code file as it comes out of Sheetcam with a text editor and see what it looks like there just to verify my hypothesis
Without knowing what your Post processor or equipment is, that's the best I can come up with.
Router
Laser
Router
Laser
Do you refresh the operation after you change the tool?
If you changed the feed in your tool definition you need to use the 'update operations' button to apply it. If you are just tweaking the value for a specific job you are better off changing the feed directly in the operataion.
I have this same issue, when I set a variable or even make a merged tool path with two different feed rates. I have never seen Mach 4 respect those settings. I have brought it up before to my Table Support Tech but I could tell he didn't believe me. It does write it in Gcode but somehow it doesn't make it to the Gcode when loaded into Mach. I have verified this happens weather I'm using Sheetcam or Vectric 2D pro. Therefore I'm guessing it must be a setting in Mach or both Post Processors have an error. Any ideas ??
TruCut CNC XT 4x8
PM-950 Mill
G0776 13x40 Lathe
PM-950 Mill
G0776 13x40 Lathe
If you look at your G-code in the first few line you will see G20 (inch) or G21 (metric)
