sheetcam problem
sheetcam problem
sheetcam not working properly when i do simulation it says your feed rate is 0 and when i going to make g codes its file is 0byes
- tnbndr
Re: sheetcam problem
Go to the Help/About and make sure it is a licensed version.??
A license is not required to do the first 150 lines of code unless its a pirated version. So you should get SOME code If you have operations defined with a tool and feed rates and have the contours on the layer associated with the operation. You should see the blue wider toolpaths as you define the operations. You have to select the correct POST processor to get code.
thanks my problem is solved
