2021 Arclight Dynamic 6x12 w/ Hypertherm Powermax105
2021 Arclight Dynamics Arc Max table with a Hypertherm Powermax 105 plasma machine.
I have had this table for a year and it works great. The only reason I'm getting rid of it is to get a machine with an oxyfuel setup to cut thicker material. I have cut everything from 16 gauge to 1 1/4" steel. The computer comes with Qcad to create the .dxf files, Sheetcam to assign operations and CandCNC control. The table will also come with an engraver, a hand held pendant and auto tracer. I am asking $30,000 since it is less than a year old and has been well-maintained. If you have any questions, or need anymore pictures, message me.
- 5.5 Star Elite Contributing Member
Re: 2021 Arclight Dynamic 6x12 w/ Hypertherm Powermax105
That auto tracer is a nice feature, and typically about a $300 upgrade from Arclight Dynamics. So that is great that you already have it.
- tnbndr
Nice setup!
What in the world are you cutting heavier than 1-1/4" for? Wouldn't it be easier to change out the plasma unit and torch head?
Good luck with the sale
PM45
Miller 215
RW 390E Slip Roll
PM45
Miller 215
RW 390E Slip Roll
Hi David, the auto tracer is a nice feature. It's great for replicating oddly shaped parts.
Dennis, I work with agricultural equipment and there are some parts that need to be pretty thick. I also work with 3/4" plate constantly, so I figured upgrading the plasma machine will increase productivity... hopefully.
I was wondering the same thing. Why not just modify so you can mount the oxyfuel head and have dual capability? But if cost is no object, then I completely understand that purchasing a new turn-key system might be the best and easiest way to go for you.
I failed to mention that I'm going to be getting a Maxpro 200 with the new table. I'm not just buying a new table for the oxyfuel setup.
That sounds very interesting. I found this thread where Jim Colt was discussing the Maxpro 200 vs. High Definition plasma.
viewtopic.php?t=12208
Lots of great information here.
- tnbndr
Got it!! You should be covered for everything at that point.
Good Luck
PM45
Miller 215
RW 390E Slip Roll
PM45
Miller 215
RW 390E Slip Roll
