Arclight Pro 9600x 4x8 CNC Plasma system $16,000
Buy and sell used plasma cutting and related equipment here.
Cmike969
Post by Cmike969 » Sun Jun 23, 2019 11:02 am
Hello all,
I have my Arclight system up for sale. I purchased this system in August of 2018 and have maybe cut 10 square feet of light sheet metal with it. The system works great, I need to sell due to medical issues.
The ArcPro 9600X 4'x8' CNC Plasma System includes: - Fully Assembled Plug and Play CNC system with hybrid frame capable of handling 1” thick plate -New Linux minicomputer w/ 19" LCD monitor, keyboard and mouse - Ventilated rack-mount control cabinet with emergency stop shut-off switch - Motor covers and Z-axis cover protect drive assemblies from dust, water, and sparks - 3" deep galvanized water pan with drain absorbs smoke and dust while cooling material - Industrial Cable Chain for wire management on both X and Y axes - Automatic Torch Height Control w/Touch-and-Go initial height sensing integrated into controller - Dual 620 oz stepper motors on gantry with 3:1 ratio rack and pinion drive for fast acceleration - 620 oz stepper motor with 3:1 ratio R&P drive on X axis, 620 oz stepper motor lead screw on Z axis - Wi-Fi access included for easy connection to your home or shop network - Printable CNC System operator’s manual and instructional videos and manuals for all software.
Hypertherm PowerMax 65 w/ machine torch set up integrated into CNC.3, HYT SIM KITAdvanced controller and Hypertherm plasma communication. Automatic amperage/air pressure adjustment,dialogue window and a “Softpierce” feature, prolonging consumable lifespan. Air Filtration Unit5 Stage Air Filtration Unit- Provides clean dry air to the plasma unit by removing water, oil and contaminatesfrom the air supply. Double Slats-Reduces slat spacing to 1.5 inches.Feex Rollers-96006 x rollers help ease the loading of large, heavy plate onto the slats. Hypertherm PowerMax 65 amp Consumable Kit includes 5- 65 amp nozzles, 3- 45 amp nozzles, 10- electrodes, 5-fine cut nozzles. 1- replacement 65/45 amp shield, 1- fine cut shield and 1- replacement swirl ring
Plate Marker / Engraver Package and Auto Tracer system also included. Along with 5 gallons of anti corrosive.
Arclight offers lifetime tech support and I can deliver within 800 miles of my location in southern Montana.
Price is 16k for entire system including the 800 mile delivery.
Thank you
Chad
Toyotawheeler79
Re: Arclight Pro 9600x 4x8 CNC Plasma system $16,000
Post by Toyotawheeler79 » Fri Jul 12, 2019 10:44 am
This still for sale ?
Cmike969
Post by Cmike969 » Fri Jul 12, 2019 12:32 pm
Yes it is
Toyotawheeler79
Post by Toyotawheeler79 » Fri Jul 12, 2019 8:09 pm
Sent you a pm
gte921n
Post by gte921n » Sun Aug 04, 2019 10:57 pm
Was this sold or still available?
spolson
Post by spolson » Thu Aug 15, 2019 11:15 am
Also wondering if this has been sold. Live a short distance away in Wyoming.
Return to “Classified Ads”
