Hey Guys.
Just a quick question please.
In the process of setting up a rotary cutter on my machine but having issues with Mach 3. I have drawn up a file but Mach 3 will not show the pic in the box where the normal picture goes. Is there a way to get this showing at all?
Thanks in advance.
Mtw fdu.
Mach 3 and Rotary Cutter
Camcutcnc 4 x 4 plasma cutter with UC 100 Motion Controller
Powermax 45 with Machine Torch
Bobcad V27 and Mach 3
Proma THC
Now with Rotary Axis
Laser cross hairs
Proma THC
Laser cross hairs
Re: Mach 3 and Rotary Cutter
Interesting I cut this on my rotary cutter and it showed fine in Mach
tried to send >TAP of TXT files no go
https://www.youtube.com/watch?v=mDO9sx8NiPA
I think I now know why it is not loading. The g-code loads but the pic does not.
You can see the cut path but that is "not" in the x, y, and z screen. I need to move my drawing to that space.
Here is a pic of it.
I will see if I can move it into the correct position.
Mtw fdu.
Mtw fdu.
- Attachments
- DSCF0431.JPG (208.72 KiB) Viewed 693 times
Proma THC
Laser cross hairs
Proma THC
Laser cross hairs
