Help with Proma 150 and Mach3
Mach3 and Mach4 from Artsoft questions or tips can be posted to this forum.
tas99
Post by tas99 » Tue Mar 24, 2020 9:07 pm
I have a Proma 150 and Mach 3 and when in Proma test mode I can see the Torch On, TorchUp and Torch Down signals operating correctly on the Diagnostic Screen but the Z of the torch never moves.
Is it supposed to move up and down in Test Mode?
I think I've enabled THC in Mach3 properly but does anyone know all that should be done to get it to run?
Any help would be greatly appreciated.
Tom
Re: Help with Proma 150 and Mach3
Post by acourtjester » Tue Mar 24, 2020 11:07 pm
It has been a long time since I used a Proma, try making the HYS voltage higher that may give you a longer time for the proma to move. And that would give you a longer time for each function. Again not sure.
I have this image from back then try that check box on I know I have seen the Z move up/down, but cannot remember what setting made is happen.
tas99
Post by tas99 » Wed Mar 25, 2020 3:58 pm
I have that box checked along with THC on the Program Run screen as well as Allow THC UP/DOWN Control even if not in THC Mode.
Post by acourtjester » Wed Mar 25, 2020 4:28 pm
her is another thing do you have this box on click on the button to turn it on/off
tas99
Post by tas99 » Wed Mar 25, 2020 7:40 pm
Yup, I have that box checked as well.
Post by acourtjester » Wed Mar 25, 2020 10:23 pm
Here is a write up I did when I first installed the Proma (2013) don't use them anymore.
THC install info.pdf
tas99
Post by tas99 » Thu Mar 26, 2020 4:27 pm
Thanks for the video.
I tried it with and without that box checked, no difference.
The THC up and down signals are being seen by Mach3 because I can see the THC lights (up/down) alternate on the diagnostic page in sync with the up/down signals from the THC I just don't see any corresponding up/down movement on the Z/torch head.
Post by acourtjester » Fri Mar 27, 2020 9:37 am
Have you actually performed a cut with the THC, since you have seen the indication in Mach it may work fine. Set the HYS voltage to 1 volt so you will see movement of the torch with small changes for testing. Cut about a 6 inch line and you should see if things are working, just watch the Z DRO for movement.
tas99
Post by tas99 » Fri Mar 27, 2020 6:58 pm
I haven't actually run the plasma cutter yet. I'm in the process of finishing the water pan which is the last item and I'll give it a test run then and let you know what happens.
Return to “Mach3 & Mach4 CNC”
Industry Pros use FastCut CNC
