Importing Bitmap Image
New to Plasma Cam and need help with importing a bitmap image into Design Edge. I have a black and white image that has been converted to a bitmap file and put on a USB flash drive. The following is what I have tried. I have opened Design Edge, clicked new drawing, grid shows up on the monitor screen, click file, Import, Import dialog box appears and the image is listed, click on the image to be imported, file name appears in the file name box, click open, Import bitmap image dialog box appears with the image, show image in drawing is checked, convert to vectors is checked, convert to colors is black and white, click next, Pick background colors, click white, click next, Image type solid is checked, click next and the Image appears on the screen with a green outline and there are no grid marks to position the work on to the metal to be cut. What am I doing wrong?
Re: Importing Bitmap Image
Here is a sample bitmap image and the steps I would use to import/trace using Design Edge. The imported image normally comes in displayed at the lower left corner of the screen - which would be the front left corner of the Plasmacam table. You can use the move command "M" to move it around the table and position it at the exact location you want to cut it from your sheet metal. This particular example would need some editing (in Design Edge) before it is ready to create cut paths.
Step 1 - Rabbit - bitmap image to import Step 2 - Import Bitmap Step 3 - Select Background Color - Black Step 4 - Select Image Type - Outline Step 5 - Click "Next" to display bitmap image and vector paths
Step 6 - Uncheck "Show Bitmap" to hide Bitmap
Step 7 - Vector Image ready for editing and creating cut paths
good on you, adbuch.... for taking the time to explain something to a beginner.
Johno
Johno
thank you adbuch I will try that
Let us know how it goes for you. Lately I have been using Inkscape or LightBurn for auto tracing jpeg/bitmap images and I find it much quicker and more convenient than importing to Design Edge.
- rdj357
You just need to press F11 or toggle the Show Bitmap option in the view menu to hide the picture so you can see the grates/table.
Robert Johnson
Learn Plasmacam Workshops
Learn Plasmacam on Facebook
Learn Plasmacam on YouTube
