Page 1 of 1
Design edge not following cutpath
Posted: Fri Aug 04, 2017 3:16 pm
by i_r_machinist
I have a new trainee and I think he changed a parameter or something because my cutter does not follow the path now.
any ideas?
thanks
i_r_
Re: Design edge not following cutpath
Posted: Fri Aug 04, 2017 11:29 pm
by Gamelord
Probably added one single dot outside the part and the cutter is going to that dot and then coming back.
Posted: Sat Aug 05, 2017 10:35 am
by see&see
Yep, a hard to see almost invisible line remanent with maybe an oversize kerf setting causing the cut path to wander where it thinks it needs to be.
If you want to upload that pcm file myself or someone else here could take a look at it....
Posted: Mon Aug 07, 2017 9:19 am
by i_r_machinist
Yup, Kerf settings! All better now.
thanks
i_r_
