Torchmate Lead Out Issue
I have a Torchmate II table. I am having an issue from time to time with cutting a circle with male tool path on plasma. When it cuts the circle back to the start point, it cuts into the part about .125". Where can I fix this issue in the driver software, I have Torchmate 3 driver software. Any help greatly appreciated, I am new to this. Thanks
Re: Torchmate Lead Out Issue
Have you set a lead-out when you set up the tool paths? If so, is it an arc or a line? And at what degree did you set it? Possibly change the degree of the angle or arc. Do you have a screen grab of the tool path? Look at that and see what the end of the cut looks like.
