Slight issues with Torchmate Software v.9.1
Post your questions or tips on Torchmates software in this topic.
Annonymous_guy_333
Post by Annonymous_guy_333 » Fri Jan 12, 2018 11:33 am
So I am a Junior in highschool attempting to cut out 3 individual designs out of 16" steel. I've vectorized the images, created the tool paths, and sequenced. However the issue I am running into is that I do not know what to do next (Neither does my teacher since he hasn't used the software). If someone could give me the steps to properly get a design set up in Torchmate CAD and how to convert it from an EDU file to a GM (Or DXF....Can't remember which comes first) that would be much appreciated!
kchoghead
Re: Slight issues with Torchmate Software v.9.1
Post by kchoghead » Mon Feb 12, 2018 9:09 am
post the file and i will try to help
DaltonMurphy
Post by DaltonMurphy » Tue Mar 20, 2018 9:58 am
u have the torchmate cad program with the white box? then u need the torchmate program with the black box that links the machine to the signal generator and import what you have programmed into that torchmate program.
