Text Welding
Torchmates software related questions and tips can be posted here
ampuck2
Text Welding
Post by ampuck2 » Thu May 13, 2021 5:08 pm
First time post here.
I am trying to add text to a home decor sign that I purchased from Etsy. I'm using the DXF version of the file and select connect path after I import the sign image. I am trying to put a last name in the center of the graphic but I've tried welding both with just regular text and then after I turn the text into a graphic. IT WILL NOT MERGE WITH THE DXF! I made sure that the font was overlapping on the top and bottom portions of the letters. I am very new to Torchmate CAD but am about to pull my hair out trying to get this to work. I added the picture of what the sign looks like and an example of a finished sign for reference. ANY help is greatly appreciated!
Re: Text Welding
Post by djreiswig » Thu May 13, 2021 7:49 pm
Not familiar with Torchmate cad, but in my cad program you have to explode the text into arcs & lines or polylines to be able to join it to other entities. Graphics or text are on a different layer.
jmersereau
Re: Text Welding
Post by jmersereau » Thu May 13, 2021 9:02 pm
Here is the info I think you need...
Jim
PrimeWeld CUT60
Langmuir CrossFire Pro
AREA
Re: Text Welding
Post by AREA » Fri May 14, 2021 9:34 am
Helpful video Jim, thank you for digging that up!
ampuck2
Re: Text Welding
Post by ampuck2 » Fri May 14, 2021 1:36 pm
That was the first tutorial that I watch. But when I try to weld the text to my DXF file it still leaves the overlapping portion of the letters with a red outline.
ampuck2
Re: Text Welding
Post by ampuck2 » Fri May 14, 2021 2:55 pm
I took a small video but I can't attach the file type to the thread. I did attach a picture of what's happening. The steps I took to get this were:
1- Import File
2- Select al pieces of DFX and Xor weld.
3- Select all and connect path
4- Add text and resize it. Center it with the graphic.
5- Basic weld
This is my result after the basic weld.
Return to “Torchmate Software”
Industry Pros use FastCut CNC
