Dose any one know how to view a .tap file other than opening it in mach3
can it be opened in sheet cam or does some one know of a .tap file viewer
thanks danny
.TAP file viewer
.TAP file viewer
2X2 Shop built table,proma thc,TB6560 bob
TD cut master 52,SL 100 machine torch
mach3, sheetcam, 26cfm compressor, Ref.air dryer, water seperator, motorguard toilet paper filter
Re: .TAP file viewer
There a G-code views. Google G-code views, some free some really proud of their work.
Don't remember which one I have on the other computer. I'll repost when I get over to that one.
Platform CNC Plasma table
CandCNC Ethercut IV DTHC
Hypertherm 85/CPC/RS485
Miller 350P
Miller Dynasty 280DX
Miller 350P
- pertneer
If you just want to see the code use notepad in windows. it is just a text file.
- WyoGreen
As pertneer says, notepad works fine for viewing and editing the .tap file, it's all I use.
Router
Laser
Router
Laser
Notepad is also what is used by Mach 3 to edit G-codes form there too. As long as you select it in the General config page and the Editor.
Ever better is a free utility called NotePad++ that is a lot easier to edit with and save files and work on multiple files at the same time.
I was wanting to see the actual drawing. I know it is note pad some times I forget what I have named something and think what the HE** is that.
I will try the g code view sphurley I tried searching every thing but that.
Is their a way to open a .tap file in sheetcam?
SheetCam has it's own simulator that runs it also. It is not always 100% right on how it will cut especially on open lines so sometimes you have to read the G-code and verify its not making multiple trips on open lines. I have also found on open lines if you put a lead-in of .01 or some real minimal number that fixes open lines.
Miller 350P
Miller 350P
