centering
Corel Draw Graphics Suite related questions and tips can be posted to this topic.
curlyweld
centering
Post by curlyweld » Fri Aug 05, 2016 11:14 am
I'm switching from cd4 to cd5. How do you keep your drawing in the center?? Thanks,,Curly
Gamelord
Re: centering
Post by Gamelord » Fri Aug 05, 2016 6:59 pm
Not sure what you are asking, are you wanting the drawing centered on the monitor or are you trying to center the objects on the drawing? To center on the monitor you can use the mouse wheel to zoom in and out, it is a little tricky to get use to but after a while it is pretty easy. If you want to move the entire drawing around, you can use the "Ctrl+A" command to select all, then click and hold onto any piece of the drawing and you can move everything to where you want it.
If you are trying to center items in your drawing (eg: putting a circle centered inside of a square), you would use the "Align And Distribute" flyout. This can be found under the "Arrange" pull down menu. Select "Arrange", then "Align And Distribute" and then you can select individual actions or choose the bottom selection labled "Arrange And distribute" and it will open up the allign tool box, from there you can check box what you want to center and how you want it done.
Hope that helps.
muzza
Re: centering
Post by muzza » Fri Aug 05, 2016 7:36 pm
Or if you want to centre the drawing or whatever to the page select it and hit "p" that will centre it on the page.
So if you want a circle in the the centre of a square you can draw the square and hit "p" then draw the circle and hit "p" and it will be centred.
A tip for another one, if you want a circle off set in the square by say half an inch to the left, do as a above and then select the circle. At the top left you will see coordinates where the centre of the selected object is in relation to the zero of the page. Deduct 1/2" from the"X" coordinate and hit enter and it is now offset by half and inch. To go go right increase it by 1/2", same with the y
If you want to do this with something that is only centred either vertically or horizontally you can use the same teknique with the align and distribute flyout.
Murray
rons
Re: centering
Post by rons » Fri Aug 05, 2016 9:48 pm
If your mouse is not zooming to the part.
Go to tools, options, workspace, toolbox, zoom and pan, check box the center mouse when zooming.
This is on 7 but should be close
4x8 Home made with PPL Gantry
Bladder water table
Candcnc EtherCut + DTHCIV
Hypertherm PM 65 machine
Sheetcam, Mach 3
Corel DrawX7
TurboCad 2015
211 Miller Mig
Ingersoll Rand 7.5 hp 80 gal
Harbor Ref. Dryer
