Splines to dots
Corel Draw Graphics Suite related questions and tips can be posted to this topic.
jfelker81
Splines to dots
Post by jfelker81 » Tue Jan 19, 2016 6:54 pm
Hey guys, im fairly new to corel. I have Corel X7, when exporting to dxf (autocad 2000 version) i sometimes "lose " some splines. They appears as just dots, when you click on them in autocad (2016 version) you can see what the spline is supposed to look like but its just a single dot. I have attached a file that has 9 of these messed up splines, if someone could point me in the right direction that'd be awesome, thanks again
Circle of Love.dxf
(272.57 KiB) Downloaded 25 times
Circle of Love.cdr
(424.07 KiB) Downloaded 10 times
Cincinnati CL-940 4000 watt Fiberoptic Laser 5' x 10' Dual Pallet
muzza
Re: Splines to dots
Post by muzza » Tue Jan 19, 2016 8:38 pm
I opened your dxf in X5 and everything looks fine. I can't open your X7 file as mine is an earlier version but what may be giving you grief is the Acad version not being compatible, personally I have had best success with 2008.
Murray
jfelker81
Re: Splines to dots
Post by jfelker81 » Tue Jan 19, 2016 9:15 pm
Tried all versions of dxf, all do the same with those 9 splines. But when i run it through my nesting software its all there, which is the important thing. If i use pedit in cad and turn them into polylines my laser really slows down on those vs the splines.
