Bolt holes in a circle
OTHill
Post by OTHill »
How do I build a circular bolt hole pattern in X6?
CNCCAJUN
Re: Bolt holes in a circle
Post by CNCCAJUN »
Can't tell you how to do it in Corel . . . but if it would help, send or post specs and I will produce for you in AutoCAD . ..
Dynatorch 4X4 XLS
PowerMAX 85
Baton Rouge, Louisiana
RNOPLASMA
Post by RNOPLASMA »
I'm far from a pro but this is how I go about it:
Draw a circle to the diameter of your pattern
Draw a circle to the diameter of your bolt
center the bolt on the top quadrant of the pattern
Click on the center of the bolt and drag the rotation point to the center of the pattern
click on arrange > transformations
In the docker I use the rotate button and enter the degree of rotation and set how many copies then apply.
You can also set the rotation to XY coords using the position button.
Hope this helps.
muzza
Post by muzza »
Keith (Beefy) had a video on doing it but it doesn't seem to be working but here is a link to a how to that Gary put up a while back.
Murray
http://www.plasmaspider.com/viewtopic.p ... nge#p35856
OTHill
Post by OTHill »
That's just great thanks everyone I got it.Allan
Sampson Jones
Post by Sampson Jones »
Buy cad 5 from macro monster.com
CandCNC electronics
Hypertherm powermax 65
Command Lineux
Super z 2
Inkscape and corel draw
Capstone
Post by Capstone »
There's a formula that you can take from this sheet. It's a milling form I found which provides the proper figures to exactly place equally spaced holes around a set diameter circle. Simply take the diameter multiplied by the figures. It may be of use to some, if you're mathy. :D
Bolt-Circle-Chart1.pdf
Bolt Circle Chart
(48.18 KiB) Downloaded 117 times
Phil
It's all relative...
CNC Metal Design
Instagram CNC Metal Design
JD Squared 4x8
HT PM45, Miller 251 MIG
