I Just started saving all my files as SVG instead of DXF. It seems like the files transfer to Sheetcam better with no clipped corners or messed up pieces like I was getting with DXF files occasionally.
Any other benefits or disadvantages? Besides not being able to upload them here.
SVG vs. DXF
SVG vs. DXF
Dynatorch 4x4 SuperBee, Powermax 65, Quincy QT-54, Snap On MM250SL, Thermal Arc Arcmaster 185, Corel Draw X7 and a messy garage.
Re: SVG vs. DXF
You can upload svg files here. They do seem to hold true better than dxf files.
Murray
Murray
Re: SVG vs. DXF
Good to know. For some reason I didn't think SVG was supported.muzza wrote:You can upload svg files here. They do seem to hold true better than dxf files.
Murray
Re: SVG vs. DXF
It was added not that long ago.
Murray
Murray
- Capstone
Re: SVG vs. DXF
My experience lately using Inkscape has proved multiple times that Sheetcam more easily converts .svg files into perfect, usable .tap files, than Inkscape can convert an .svg into .dxf first. So from here on out I'll go that route. The only challenge left for me is manipulating a .dxf file in Inkscape which is not as easy as it sounds.
Phil
It's all relative...
CNC Metal Design
Instagram CNC Metal Design
JD Squared 4x8
HT PM45, Miller 251 MIG
CNC Metal Design
JD Squared 4x8
- 4.5 Star Member
Re: SVG vs. DXF
The DXFTOOL add on is great for exporting DXFs without the said problems. Gives much nicer lines in general. Coreldraws basic DXF export stuffs it up regularly for me, so if I'm using DXF I first check it out in Sheetcam. I don't know how such simple drawings can get so grossly stuffed up.
SVG works great most of the time.
Keith.
Keith.
2500 x 1500 water table
LinuxCNC
Coreldraw 2019
LinuxCNC
Coreldraw 2019
Re: SVG vs. DXF
I'm going to just use SVG for everything now, It comes out more true in Sheetcam and it seems to save to smaller file size than DXF.beefy wrote:The DXFTOOL add on is great for exporting DXFs without the said problems. Gives much nicer lines in general. Coreldraws basic DXF export stuffs it up regularly for me, so if I'm using DXF I first check it out in Sheetcam. I don't know how such simple drawings can get so grossly stuffed up.
Keith.
- CNCCAJUN
Re: SVG vs. DXF
SVG files are nice but they don't work in AutoCAD . . .
Dynatorch 4X4 XLS
PowerMAX 85
Baton Rouge, Louisiana
Dynatorch 4X4 XLS
PowerMAX 85
Re: SVG vs. DXF
I also have had much better luck with svg than dxf. I use inkscape almost exclusively now.
Precision Plama LLC SDB 5x10
CandCNC
Hypertherm 65
Mach3
SheetCAM
the GIMP
inkscape
QCAD
https://www.facebook.com/burtonskustom
CandCNC
Hypertherm 65
Mach3
SheetCAM
the GIMP
inkscape
QCAD
