Squaring plasma torch head to table
ALLOHIO
Post by ALLOHIO »
What is the best way to square the torch head to the table, and if my table grid is burned up in the center should i level the 3/8 steel that i am cutting.
I am using a Tracker plasma table with a Thermal Dynamics plasma cutter. Thanks
ALLOHIO
Re: Squaring plasma torch head to table
Post by ALLOHIO »
Thanks leatherhands do I square it to the torchhead or the bracket?
ALLOHIO
Post by ALLOHIO »
No I dont I put an air dryer next to the cutter i am trying to figure out how to put a square on the torch with the bracket in the way sorry to sound like an idiot but the book showed a square just not room for it thanks.
ALLOHIO
Post by ALLOHIO »
Thanks you have been a great help
bisonfabuilder
Post by bisonfabuilder »
I to use a Tracker and a thermal dynamics 101 torch head. To square the torch, I use a 3" machinist square on the nose cone of the torch and a new 1/4' plate for the base and it works good for me! It is a lot easier that way then trying to square off the body of the torch.
