Going to the hive mind on this one... I'm new and have only about 1 hour of cut time under my belt.
I was cutting some trinkets for practice and for the life of me cannot figure out why I keep cutting bevels on my parts. I get a 90 at the top of the cut, but create a bevel at the bottom. After removing dross it almost turns into a knife edge which is unacceptable. Its about a 15 to 20 degree angle.
I put new consumables in the torch, played with feeds & speeds and power source output to no clear solution.
Cut parameters:
16Ga hot rolled sheet
Cutting 30 amps on machine
about 900-1500 mm/min
60-65 PSI at torch
Torchmate table
Jasic Razorweld power source
Tool path created in Fusion 360
If you have any suggestions I'm open.
HELP How to control cut 90 degree vs bevels
- ben de lappe
Re: HELP How to control cut 90 degree vs bevels
Could be a torch height issue as the plasma beam is not straight, shaped more like the flame of a candle.
Cut direction?
clockwise for outside offsets (parts).
counter-clockwise for inside offsets (holes).
https://www.hypertherm.com/Download?fil ... &zip=False
+ torch height as Ben said previous.
Thanks for the replies. I'll run through the set up process again and try optimize torch height.
Thanks for the suggestions.
