1250 g3 other charts
So I have a samson 510 with a powermax 1250, I have all the cut charts but I'm having a hell of a time finding charts for proper kerf (or nozzle orifice size to multiply it by 1.5), air pressures. I understand that hypertherm has multiple models but Why do we not have charts for these?
Samson 510
Hypertherm powermax 1250
campbell hausfeld 60 gal
Hobart ironman 230
3/4" blade band saw
4ft finger brake
Miller diversion 180
Millermatic 140
Hobart ironman 230
3/4" blade band saw
4ft finger brake
Millermatic 140
Re: 1250 g3 other charts
I couldn't find kerf width charts for the 1250 either. Just set your machine up to cut a 6" straight line at the appropriate speed, height, and amperage and then measure the kerf width, document it for future reference and your all set
- SegoMan DeSigns
Does it have the older machine torch or the newer Duramax? You could probably takes the values from the 85 and be close.
I have the T80 torche
Samson 510
Hobart ironman 230
3/4" blade band saw
4ft finger brake
Millermatic 140
Hobart ironman 230
3/4" blade band saw
4ft finger brake
Millermatic 140
- Nacs Fab
I have some cut charts for this machine, let me see if I can find them and upload them here. At one point, I got the kerfs from either here or on another forum where Jim Colt posted for both the older torches as well as the new Duramax torch, which I have. Give me a day or so and Ill see what I can find.
G540 with LCTHC by candcnc
all built... by me...
not the answer you want but it was from Jim colt for the 1250 and he should know
https://www.cnczone.com/forums/hyperthe ... forum.html
this may or may not be of use to you too
https://www.google.com/url?sa=t&source= ... 8828035037
https://www.google.com/url?sa=t&source= ... Ttqq2t9e9w
although NOT for the 1250 may still be of use
https://www.google.com/url?sa=t&source= ... 8828205934
- Nacs Fab
Here is what i use without any problems using my Duramax Torch but I also used it when I had my old T80M (i belive thats the name of it).
- Attachments
- kerf width.doc
- (302 KiB) Downloaded 52 times
Cool cool. I'll use the pm 85 chart as much as possible
Samson 510
Hobart ironman 230
3/4" blade band saw
4ft finger brake
Millermatic 140
Hobart ironman 230
3/4" blade band saw
4ft finger brake
Millermatic 140
