Poor quality cuts and random errors
Gunfighter
Post by Gunfighter » Sun Nov 04, 2018 12:05 pm
I am new to plasma cnc. After table was delivered everything was fine. Then, I had a loss of air which caused the torch to die off in middle of a cut. I fixed the air issue and replaced the consumables. Now it cuts weird jags in every file. These files cut fine previously. I attached pics of:
All cut out of 16 g steel
2.5 inch circles
6 x 6 square with hole
4 x 4 square with 4 holes
logo - top was cut prior to issue, bottom after
I have a custom table by Cyrius Metalworks. A Hypertherm 65 plasma. Command cnc control software. Sheetcam software
Air pressure is - 100 psi to torch. Double water filter. Gauge at torch.
I have read through forum for similar issues before posting. I don't know how to adjust torch height in the program.
I appreciate any and all advice. Please make advice understandable for a newbie. Thanks again!
Re: Poor quality cuts and random errors
Post by acourtjester » Sun Nov 04, 2018 10:29 pm
You have a problem in the drive system something is loose. When you transfer between X and Y axis movement something shifts, it also appears where you cut the outside of the square as the end does not meet the start in the upper left corner.
Could be a setscrew in the drive is slipping
Everlast PM 256 tig
Gunfighter
Post by Gunfighter » Sun Nov 04, 2018 10:34 pm
You are absolutely correct. Since posting earlier today I found a tiny loose set screw on the Z axis drive. All good now. Thank you for your post. I am sure I will need more help in the future.
Post by acourtjester » Mon Nov 05, 2018 9:26 am
Great many here happy to help
I like to file a flat on the shafts where the setscrew touch to help reduce slipping too.
Everlast PM 256 tig
Users browsing this forum: No registered users and 4 guests
