slag buid up on the sheild while using fine cuts
Jhirschman
Post by Jhirschman »
im cutting 16ga cr with fine cuts and the slag is building up on the shield as its cutting messing up cuts. any help would be great thanks!!
WyoGreen
Re: slag buid up on the sheild while using fine cuts
Post by WyoGreen »
I have read on some of the threads on Plasma Spider that people are using Mig splatter spray to reduce the sticking of the slag to the plasma cutter shield.
Precision Plasma gantry
HT-45 plasma cutter
Plate Marker
Router
Laser
quadboy
Post by quadboy »
Try raising you Pierce height control. Or you cut to plate distance which might be arc voltage. Hope this helps
Paint Chip
Post by Paint Chip »
In addition to pierce height,have you confirmed that you are at the correct cut height - might be your z axis offset is off. I use a feeler gauge from time to time to check it. Also, the MIG antisplatter dip is a great tip - really helps avoid issues with Aluminum and heavy gauge steel where the speeds are slow.
PPLLC 4X8 table w 620 ox steppers on 5 axes
Bladerunner CandCNC w/DTHC II
Hypertherm PM85
motoguy
Post by motoguy »
That's just part of the game with finecuts, IMO. Builds up on that shield much faster / more annoyingly than on the regular shield.
SeanP
Post by SeanP »
I've tried all ways and the best so far for me is to ditch ohmic and go unshielded, I actually think you get a better cut and less problems.
Powermax XP45
R-Tech 210 Tig, Jasic 250 mig
Table build gallery
