It is currently Thu Oct 18, 2018 10:57 pm
Air Dryer Question
Jfile
Air Dryer Question
Postby Jfile » Wed Sep 19, 2018 9:48 am
Finally got around to trying out the refrigerated air dryer that I bought from Harbor Freight. I thought that the small tube stubbed out the side was so that any moisture pulled out of the air would be able to drain out. Is a fairly steady flow of air supposed to come out of that tube all of the time?
LDR 4'x4' Water Table
Command CNC Linux Controller
InkScape / SheetCam
cuttinparts
Re: Air Dryer Question
Postby cuttinparts » Wed Sep 19, 2018 12:04 pm
I don't have the Harbor Freight dryer, I have a different brand of refrigerated dryer but would not think that a steady flow of air should escaping. Mine has a small hose also and I think there is a solenoid on a timer and every once in a while it will open and air/moisture will escape the hose for a second or two.
Postby djreiswig » Wed Sep 19, 2018 12:31 pm
It has a float in the moisture trap that blows the water out when it gets full. It also drains when the air pressure is relieved. It must have something stuck in it.
Users browsing this forum: No registered users and 8 guests
