It is currently Sat Oct 20, 2018 3:28 am
Torch dragging
Brendog44
Torch dragging
Postby Brendog44 » Fri Dec 08, 2017 3:46 am
Hi there, trying to cut thin mild steel at 2.5mm but the torch seems to be dragging itself around rather than cutting at its normal level. Also the dthc isn't lifting the torch up. Only seems to be an issue on the thinner sheets still seems to be cutting 6mm and above okay. Does anyone know a fix for the problem.
Thanks.
sphurley
Re: Torch dragging
Postby sphurley » Fri Dec 08, 2017 11:57 am
A "little" information on your system would be the first step.
Platform CNC Plasma table
CandCNC Ethercut IV DTHC
Hypertherm 85/CPC/RS485
Miller 350P
Miller Dynasty 280DX
Re: Torch dragging
Postby tcaudle » Fri Dec 08, 2017 12:04 pm
If it cuts thicker material okay then its a setting. Its trying to keep the voltage DOWN . With no info on what settings you ae using, what kind of torch/plasma, what consumables, etc, etc
What does it do if you turn off the THC ? What is the actual torch volts during a cut with the THC disabled?
Brendog44
Re: Torch dragging
Postby Brendog44 » Mon Dec 11, 2017 5:21 am
It's a swift cut 3000WT
Re: Torch dragging
Postby tcaudle » Mon Dec 11, 2017 11:10 am
Swift Cut UK?
Brendog44
Re: Torch dragging
Postby Brendog44 » Tue Dec 12, 2017 4:14 am
Yes new development it's not saying 0-50 retaining cap off when it's not?
Brendog44
Re: Torch dragging
Postby Brendog44 » Tue Dec 12, 2017 4:15 am
Now saying *
Re: Torch dragging
Postby tcaudle » Tue Dec 12, 2017 9:46 am
That is a signal from the Hypertherm and its sensed by a small switch at the retaining cap. Being loose can cause that. The RS485 interface to the Hypertherm sends the message back to the control screen. It just reports what it gets from the Hypertherm electronics.
