It is currently Wed Nov 14, 2018 10:43 am
Heat Treated Metal
cfmetalworks
Heat Treated Metal
Postby cfmetalworks » Wed Oct 11, 2017 10:18 pm
Has anyone ever used heat treated metal to keep small gauge steel from warping? I spoke with another shop owner the other day and he mentioned it to me. What is your opinion?
Thor
Re: Heat Treated Metal
Postby Thor » Wed Oct 18, 2017 9:29 am
Generally in steel I just get "enhanced flatness" grade, sometimes referred to as Temper Passed. Basically instead of just being unrolled from coil and cut off, they also send it through a roll leveler with a set of pinch rolls that thins it ever so slightly which takes the memory out and hardens the surface a smidge.
Users browsing this forum: No registered users and 7 guests
