lost arc
lost arc
using 40 amp fine tips with HT 1250. Cutting 14 ga steel and kept getting lost arc and the machine would stop dead in it's tracks. Any ideas. Thanks in advance. CG
There is plenty of room at the top - and the top is where you want to be. Whenever you do a project - do the hardest part first and the rest will be easy.
- Loyd
Re: lost arc
If you have plenty of air pressure I would think that your electrode is shorted out. I had the same problem a couple of days ago with my HT 1250.
Reset your pierce height after changing consumables. Hope this helps....
Loyd
Loyd
Re: lost arc
whenever I have changed the electrode I just start the cut cycle - I have never reset the pierce height???????????????
Re: lost arc
What type of cutting machine? Is the plasma arc cutting out, or is the machine stopping movement? Have you watched the diagnostic lights on the front panel of the 1250? If you have a hand torch, have you tried cutting by hand?
Re: lost arc
dynatorch machine with a HT 1250 - the screen gives a red line message loss arc and the machine stops travel and does not retrack the torch - no hand torch. have not watch the diagnostic lights on front panel of 1250
- Scratch
Re: lost arc
Try calling Indiana Jones... he should be able to help.
Re: lost arc
If you had marginal air pressure (drops under flow conditions) or a restriction (also drops under flow conditions)....you will see the front panel air pressure indicator light show low pressure....momentarily. Then after the post flow of the plasma stops....the pressure will rise back to a safe level, and will indicate ok. You should watch the front panel indicators to determine if a momentary pressure drop is causing the loss of arc....which will drop out the transferred arc signal...giving the Dynatorch control the indication that the arc is lost.
Jim Colt
Jim Colt
Re: lost arc
Jim I will be cutting again on Monday and will watch the panel and get back to you. Thanks for your help. Scratch - Indiana Jones called me after he read your post and told me to tell you hello and he is just to old to start "Scratching" around for a Lost Arc when guys like jimcolt are on the scene and at the top of his game. Jones also said "that jimcolt knows his stuff and there is no need to even try to bluff my way through this one"
Re: lost arc
Just call me Raider of the Lost arc. Actually they were great guy flicks....
- Loyd
Re: lost arc
Yeah Jim Colt IS our Indiana Jones......
Loyd
Loyd
Re: lost arc
Jim I think a low pressure setting on my incoming air supply was the problem. One of the guys dialed the air down to air up a couple of small handtruck tires and did not increase the pressure to what it was set on before he started. Set the pressure back and cut the part without any problems. Thanks. CG
