It is currently Fri Oct 19, 2018 9:35 am
Machine settings for 3/8 plate
chauto
Postby chauto » Tue Jan 20, 2009 12:44 am
I am new to plasma cutting, Which tip size, Amp setting, cutting speed, air pressure ? I'm getting lots of slag and the cut looks poor. This is on 3/8 plate and Hypertherm 1000
Thanks for any help.
Chris
chauto
Re: Machine settings for 3/8 plate
Postby chauto » Wed Jan 21, 2009 12:36 am
I am using 80 amp tip, set @75 amps 90 psi, inside cuts are CCW outside cuts are CW, I have tried 45 to 70 ipm and still getting lots of slag on bottom side of cut. Do you think a 60 amp tip would work better?
admin
Site Admin
Postby admin » Wed Jan 21, 2009 7:30 pm
A 60 amp tip should help to reduce the slag since it will have a smaller orifice. Be sure to keep your amps at 60amps, no higher, and reduce your travel speed.
admin
kslon
Postby kslon » Thu Jan 22, 2009 9:43 pm
Hey guy just a question about cutting speed. You guy are saying to cut at 70ipm. I have been doing most of my cutting at anywhere from 2.0 to 3.0. Are we talking about the same thing?????? Also i didn't see any remarks about how to change the direction of the cut.
chauto
Postby chauto » Thu Jan 22, 2009 10:21 pm
Kslon, inches per minute, Also you can read about cutting directions under the posts poor cut quality there is very good info there.
chauto
Postby chauto » Thu Jan 22, 2009 10:24 pm
Thanks for all the info everyone, 60 amp tip @ 60 amps and 25-30 ipm, 90 psi works very well.
