HELP How to control cut 90 degree vs bevels
Engineering
Post by Engineering » Sun Dec 01, 2019 4:36 am
Going to the hive mind on this one... I'm new and have only about 1 hour of cut time under my belt.
I was cutting some trinkets for practice and for the life of me cannot figure out why I keep cutting bevels on my parts. I get a 90 at the top of the cut, but create a bevel at the bottom. After removing dross it almost turns into a knife edge which is unacceptable. Its about a 15 to 20 degree angle.
I put new consumables in the torch, played with feeds & speeds and power source output to no clear solution.
Cut parameters:
16Ga hot rolled sheet
Cutting 30 amps on machine
about 900-1500 mm/min
60-65 PSI at torch
Torchmate table
Jasic Razorweld power source
Tool path created in Fusion 360
If you have any suggestions I'm open.
ben de lappe
Re: HELP How to control cut 90 degree vs bevels
Post by ben de lappe » Sun Dec 01, 2019 8:41 am
Could be a torch height issue as the plasma beam is not straight, shaped more like the flame of a candle.
robertspark
Post by robertspark » Sun Dec 01, 2019 9:15 am
Cut direction?
clockwise for outside offsets (parts).
counter-clockwise for inside offsets (holes).
+ torch height as Ben said previous.
UCCNC,
Hypertherm Powermax 45 (nonXP)
Neuron Lite THC
Hobby user (4x4 home table)
Engineering
Post by Engineering » Mon Dec 02, 2019 1:13 am
Thanks for the replies. I'll run through the set up process again and try optimize torch height.
Thanks for the suggestions.
