Hello,
I am looking to add a THC to my plasma table. I will be using it with mach3 are there any suggestions on brand? so far its a toss up between the Proma THC and the CNC4PC THC.
I would love to hear any suggestions you guys would have.
THC Suggestions?
Re: THC Suggestions?
You can use the search function in the upper right for a look at reports of THC units. I would not use the Proma SD unit as members have had problems with that unit. I had used the Proma 150 that worked but was not reliable for long life.
acourtjester wrote: ↑Mon Jun 27, 2022 8:50 am You can use the search function in the upper right for a look at reports of THC units. I would not use the Proma SD unit as members have had problems with that unit. I had used the Proma 150 that worked but was not reliable for long life.
To new in AZ, I will look forward to seeing (or hearing) how you make out.
