Hello,
I create laser cutting programs using the program 'radan', but it doesn't work from the program to connect several small lines/arcs into larger ones to cut smoothly without interruptions. I have tried several ways to save from autocad but in radan I still get an outline in small segments.
Do you guys have a solution for this?
Smooth contur
Smooth contur
Re: Smooth contur
Your image doesn't look very choppy overall. Is it that short yellow line segment at the 3 o'clock position that your referring to?
Re: Smooth contur
Please share your dxf or other file so we can have a look.
