Pulley Search
Pulley Search
I think this might be the correct forum for this, but I am having a hard time finding a pulley I need for my plasma table. The old motor had a 3/8" shaft and the replacement motor has a 1/2" shaft. The current belt is "1/5in XL pitch, 3/8in wide, 105 tooth" and I need a pulley with a 1/2" bore in it. Maybe I am not looking in the right place but I am having zero luck. I ordered my belts from AutomationDirect and can not find them there either.
New motor = https://www.automationdirect.com/adc/sh ... mtrh-34066
Belt = https://www.automationdirect.com/adc/sh ... 210xl037ng
Added a couple of images for the heck of it. The motor goes behind the plate with the shaft coming toward you.
Re: Pulley Search
How many teeth does the pulley need?
Re: Pulley Search
That is a good question, and I am still learning the proper way to figure that out. I found a calculator for belts but not for pulleys yet.
Re: Pulley Search
I found this one but same issue is getting the correct teeth count https://www.bbman.com/catalog/product/16XL037-6FA6
Re: Pulley Search
The old setup was 10 teeth to 72 teeth. So I guess that would be 10XL pulley?
Re: Pulley Search
drill it out 1/16 th under size then ream to 1/2 inch if you cant find one pm me i will try to help you dave
- Joe Jones
Re: Pulley Search
Right. It seems it should be easy for a machine shop to convert your existing pulley to a 1/2" shaft. Why reinvent the wheel?
Franklin, KY., USA
Samson 510 & 4x4
CreatBot D600 PRO 3D Printer
12 Lasers
FREE DesignEdge Training!
Samson 510 & 4x4
12 Lasers
Re: Pulley Search
Here is one with a 1" bore you could use an adapter to bring it down to .5" There are many others with metric bore
https://www.ebay.com/itm/313428864967?h ... SwvwRgNAUQ
Re: Pulley Search
Monday, we plan on having the shaft machined down, I should have mentioned that. I guess this is more common than I was thinking then?
I am trying to document this rebuild better than how I received it. I was trying to find part numbers for the need of reordering, but I guess the shaft could be swapped fairly quickly if a new motor is needed in the future. I am overthinking it I guess LOL
Re: Pulley Search
Thanks to everyone for the help. I can not wait to get this dinosaur running and to be more modern.
- Joe Jones
Re: Pulley Search
I didn't even think about that. Remove the armature from the motor and turn it down to 3/8" ... That is probably the best idea.
Franklin, KY., USA
Samson 510 & 4x4
12 Lasers
Samson 510 & 4x4
12 Lasers
Re: Pulley Search
I would be more inclined to go with Duner405's suggestion and just enlarge the bore in the pulley. Looks like it is aluminum, should be super easy.
