Hello friends, I have a problem please help
I have a cnc plasma with a hypertherm powermax 45xp. I design with artcam 2008 + sheetcam. The problem is that the cutting device does not complete the torch to the end of the line, given that the consumables are new. Thank you
Re: Hello friends, I have a problem please help
Please show us some photos of your parts with the incomplete cuts. It would also be good to share your dxf cut program so we can take a look.
Are you talking about a single line or a shape that it does not complete. If the shape then you may not have a closed loop, the machine will follow what the G-code give it. Simple check is in SheetCam see if you can move the starting point for the cut. With a closed loop it will move to where ever you want. If it is an open shape, the start will not move.
acourtjester wrote: ↑Fri Apr 22, 2022 11:05 pm Are you talking about a single line or a shape that it does not complete. If the shape then you may not have a closed loop, the machine will follow what the G-code give it. Simple check is in SheetCam see if you can move the starting point for the cut. With a closed loop it will move to where ever you want. If it is an open shape, the start will not move.
- Joe Jones
Check to make sure that the machine is not beginning to move before the torch fires. It might not be that the torch is not completing the cut. It may be that the torch starts moving before it fires, which would leave a tab at the starting point although the torch would cut to the end of the path at the finish.
Franklin, KY., USA
Samson 510 & 4x4
CreatBot D600 PRO 3D Printer
12 Lasers
FREE DesignEdge Training!
Samson 510 & 4x4
12 Lasers
Hello brother, thank you for the information. I'm talking about the shape is not complete during the cutting process. I will do what you said on the sheetcam program by moving the starting points. Thank you
Plasmamehdi wrote: ↑Sat Apr 23, 2022 4:47 pmacourtjester wrote: ↑Fri Apr 22, 2022 11:05 pm Are you talking about a single line or a shape that it does not complete. If the shape then you may not have a closed loop, the machine will follow what the G-code give it. Simple check is in SheetCam see if you can move the starting point for the cut. With a closed loop it will move to where ever you want. If it is an open shape, the start will not move.
Nice question. I'm using mach3 extract G_code with sheetcam. The problem is during the process of cutting a shape, the torch begins to cut and the line is not completed until the end of the shape. Tomorrow I will send pictures and a video Thank you David
You are quite welcome! I will look forward to seeing your pictures.Plasmamehdi wrote: ↑Sat Apr 23, 2022 5:12 pmNice question. I'm using mach3 extract G_code with sheetcam. The problem is during the process of cutting a shape, the torch begins to cut and the line is not completed until the end of the shape. Tomorrow I will send pictures and a video Thank you David
