Optimizing ALuminum
Optimizing ALuminum
Hey guys, just wondering what you folks that mainly cut aluminum use as far as water additive? I have read about the side effects of aluminum on water, but our business is basically all aluminum and we take precaution and it has cut just fine for the most part. We were using the company that made the table's "Plasma Quench" which worked fine when the table was primarily cutting steel at my last company. But now we get a lot of white "sudsy" build up on the slats, along with nasty staining and oxidization on the sheets of aluminum. Thanks for any ideas!
Re: Optimizing ALuminum
Try contacting the guys at www.plasmacoolant.com and they may have a solution for you
