CNC Cabinet power up control
I am working on retrofitting an old plasma machine, however because the table is 24' long, were converting 1/2 of it to a router table. ( plasma/router table) I am working on the details of how when power is turned on to the CNC cabinet, what gets energized and when. In the attached shows a On/Off circuit that basically turns on the cabinets fan and the CNC Controller only. Once the Controller is up, it energizes the motors. Is this the correct way to do this? I would greatly appreciate any advise you have to offer.
Re: CNC Cabinet power up control
I think this circuit is probably fine, but we need to know more information about the relay to confirm. I assume this is a "Latching Relay". Do you have a part number for the relay?
Your start, stop and relay wiring is correct. A standard relay will do what you need. The start will energize the relay and the stop will deenergize it.
Upon closer examination, I agree. The top portion of the relay is wired as "self-latching" and controls the bottom portion of the relay - which either turns the power on or off to the cooling fan and power supply.
Thank you for confirming this is wired properly. (I intend to use Veris VMD2B-F120A Relay) I am concerned that when turned on, only the CNC controller is powered. It is not until the Estop circuit from the Controller is energized, that the AC Motor Drives and the VFD is powered. Is this "normal" ? Is this a common method of controlling the Drives/motors? Sorry I have no experience in a motors operational control, and don't know if I need to have more control over the Drives and motors power. For example, to tune the AC Servo Drives/Motors....or perhaps something else I dont know about...Thanks for your interest..
Chris Orwig
Mach4 Hobby
Vital Systems Hicon 7866 w/ 77ISO bd and ArcPro Plasma Profile
DYN4 DYN4-H01A2-00 AC SERVO /DMM 750 Watt NEMA 34
Thermal Dynamics Pak Master XL100 w/ floating head Torch
Retrofit Table: 6’x24’ linear rail and belt. Water Table
Mach4 Hobby
Yes Chris - this is one method that would be considered "normal" for implementing the E-stop. With the E-stop switch in the normal (un-activated) position the E-stop switch circuit is closed and power is supplied to the motors and drives. In the case of an emergency (hence the term "E-Stop") you would push the E-stop switch to disable the motors and drives. My large cnc machining centers and turning center all have E-stop switches which function in a similar manner. So does my manual lathe, Avid cnc router, and several other of my cnc machines. The Plasmacam DHC2 controller has the equivalent as well.ChrisO wrote: ↑Tue Jul 06, 2021 11:22 am Thank you for confirming this is wired properly. (I intend to use Veris VMD2B-F120A Relay) I am concerned that when turned on, only the CNC controller is powered. It is not until the Estop circuit from the Controller is energized, that the AC Motor Drives and the VFD is powered. Is this "normal" ? Is this a common method of controlling the Drives/motors? Sorry I have no experience in a motors operational control, and don't know if I need to have more control over the Drives and motors power. For example, to tune the AC Servo Drives/Motors....or perhaps something else I dont know about...Thanks for your interest..
Under normal operation, your E-stop switch would be un-activated and your servo drives/motors would be powered so you can tune, etc.
In industry, this would be something like an MCR or Master Control Relay or Master Circuit.
It's to protect the machine in the event of a power loss. If the power drops, the circuit unlatches.
Your confirmation on the basic power design is greatly appreciated, Thankyou. I'll continue to draw up the remaining details.
Chris Orwig
Mach4 Hobby
Mach4 Hobby
Keep us posted on your progress Chris. It sounds like you are off to a great start!
