Greetings to everyone....i bought an lgk -100IGBT from a chinese distributor.my problem is;
-During cut the plasma suddenly goes of and move along the path of cut without cutting and if am lucky it cut the next design.
-And using sheetcam to generate my g-code .but during simulate i discover it stops at one point .i am unable to figure out where exactly the problem is coming from(sheetcam doesn't show any error sign after u click plasma cut)
I will gladly embrace your contributions
Need help with my chinese plasma cutter!!
Re: Need help with my chinese plasma cutter!!
Hi John, those cutters are pretty good, but probably you have recieved it with the cheap P80 torch which makes the trouble.
Any error lights come on if it has any?
Please can you recommend to me a good touch that i can buy to solve the problemattila0216 wrote: ↑Sun Apr 11, 2021 1:26 am Hi John, those cutters are pretty good, but probably you have recieved it with the cheap P80 torch which makes the trouble.
OK, I am not familiar with that plasma, it may not even have any but I thought I would ask first.
Do you have an air pressure gauge at the back of the plasma cutter to monitor input pressure when this problem happens?
