Magnetic Break-Away Machine Torch Mount
The-Meerkat
Post by The-Meerkat »
Crashed and broke my mount today. I’m thinking of going with a Magnetic Break-Away mount. Doing some Google searching, I see store bought ones ranging from $150 to $500. The top end one has safety cables so the torch doesn’t fall into the water below and has a switch that triggers E-stop when the magnets disconnect. I want all that. Short of spending a half-Grand or building one myself, anybody have thoughts on these things either good or bad? Recommendations?
Scott Meer
Rodw
Re: Magnetic Break-Away Machine Torch Mount
Post by Rodw »
SeanP has a very good easy to make breakaway design on this forum. I would search for it.
robertspark
Post by robertspark »
3d print one
Rodw
Post by Rodw »
What I did
The-Meerkat
Nice
Scott Meer
SegoMan DeSigns
Post by SegoMan DeSigns »
The-Meerkat
I designed one in Bobcad this week and 3D printed it while waiting for N52 magnets to arrive. The magnets came in and I glued them into place last night and covered the ones that can be seen with 3D printed plugs. I’m going to add a safety strap. Before installing, I’m also adding a couple micro limit switches to stop the machine if the two pieces come apart.
Scott Meer
robertspark
nice
SegoMan DeSigns
Should have used a bright color :HaHa
The-Meerkat
It’s definitely bright purple.
Scott Meer
maacmetal
Post by maacmetal »
Mine is very similar to Rodw I might rebuild it a bit cleaner down the road if i can get my hands on a mill.i made a quick and simple magnet mount works great so far and cost me less than $15. Works great with the one 98 lb. magnet. Could use 2 maybe if your machine is real fast. The spring loaded detents work perfect for lining up. they click into the screw holes on the bearing
maacmetal
Post by maacmetal »
weldguy
Post by weldguy »
Simple effective looking mount maacmetal, nice job. Love seeing all the different ideas here.
there are more than you think from the DIY group Here is a neat on by a member here Xnaron.. It is neat as the torch stays captive if knocked off by a collision. :Like
Maybe The Meerkat could post the STL file for those the want to try it.
