MyPlasmCNC draw a conclusion
- East German
Hello
Some are interested in the system. I started testing with my old Windows XP system.
The installation is very easy and I completed 3744 starts and 422 minutes burning time without any problems.
I have now upgraded to Windows 10 and have now completed 1087 starts and 179 minutes burning time.
I will not be returning to Mach3!
Best regards
Peter
Best regards
Peter
MyPlasmCNC
Hypertherm Powermax 85
Machine Torch
Hypertherm Powermax 1100
Machine Torch
MyPlasmCNC
Machine Torch
Machine Torch
Re: MyPlasmCNC draw a conclusion
Do you find an improvement in the finished article?
Better quality cut?
What do you like about it that you do not like any more about mach3
Better quality cut?
- East German
Hello,
The cut quality is the same. But you are more flexible because you can adjust the parameters directly on the main screen.
With Mach3 everything has to be changed in Sheetcam and you have to take into account which material is cut.
With MiniCAM you can do most of the work only with complicated things where the order is important, I still use Sheetcam.
Advantages for me:
- easy setup
- Ohmic and floating probing with different values
-Modern operating system to use Internet and Dropbox
-start from here or from a certain place no problem
- Interruption and restart no problem
-Cut simulation without starting the torch
Four things that I have set up in Mach but with a lot of effort.
Mach requires much more cables and hardware to achieve the same result.
Peter
Advantages for me:
- easy setup
Peter
MyPlasmCNC
Machine Torch
Machine Torch
MyPlasmCNC
Machine Torch
Machine Torch
thanks for taking the time Peter
I'm still in the collecting parts/designing phase of my table. I plan on using myplasm but have a few reservations.
Have you tried Sheetcam with myplasm? I haven't been able to find a post processor for it but assume this is doable. I have played around with the myplasm software and it does seem pretty decent but I prefer to have more options like sheetcam provides.
Second concern is would I be able to add a second tool? (Plate marker). On my last table (torchmate) I made my own plate marker and Les Newell built a post for me to use the plate marker but I remember setting up the #2 tool offset in the torchmate driver software. I assume this is something myplasm would have to add in the software right or could this be programmed through the post processor only?
Last hold up that's not a deal breaker for me is would myplasm be able to support a router if I wanted to add that option in the future?
- East German
I have been using the post processor for many years CANDCNCrev11j from CAND CNC.
It works with Mach3 and MyPlasmCNC very well.
MiniCAM is sufficient for most tasks and saves a lot of time. The automatic detection of the paths works very well.
I only use Sheetcam very rarely.
Because of the marker you have to write to Lukascz Prokop from Proma, I have mine, I don't need it enough.
He answers questions pretty quickly.
Peter
Peter
MyPlasmCNC
Machine Torch
Machine Torch
MyPlasmCNC
Machine Torch
Machine Torch
Thanks for the info on the candcnc post. That helps a lot.East German wrote: ↑Sun Apr 19, 2020 1:55 am
Peter
You say you have a plate marker and plate marker post? Would you be willing to share that post with me?
- East German
Plate Marker:
I have broken it down since converting to MyPlasmCNC because I don't need it.
Peter
Peter
MyPlasmCNC
Machine Torch
Machine Torch
MyPlasmCNC
Machine Torch
Machine Torch
Ok, so you haven't used the plate marker with MyPlasm. Are you aware if it's possible to use a plate marker as a second tool with MyPlasm?East German wrote: ↑Sun Apr 19, 2020 2:48 pm Plate Marker:
Peter
- East German
No I do not know.
MyPlasmCNC
Machine Torch
Machine Torch
MyPlasmCNC
Machine Torch
Machine Torch
I hope you can because the table I ordered uses My Plasm and I was planning on adding a scribe. I was told it could be done.
As of right now it cannot be done without the software being changed. I have been speaking to the developer for the last couple days. He's gonna look into a simple solution and potentially add it in the future but as of right now its not top priority. In the meantime I'm going to see if I can figure out a work around.
Kel Fab did you ever get the reply about running a router with the MyPlasm system.
I ended up abandoning the project. Sorry.
Thanks for the reply
It's junk. Had a firmware update that crashed and broke my torch and left the machine unusable. The motors randomly reverse and it crashes the gantry into the end at high speed. No one has figured this out, and I'm an inch from scrapping the whole table and buying something else. This program is utter garbage and it's only good for keeping scrapyards in business.
Is this your report on your MyPlasmCNC electronics package, this seems to be the first with problems. Any other follow up from other members with their experiences??
- East German
I have two tables running MyPlasmCNC and it works. I had a mechanical problem with a pulley but the program can't help it.
Peter
pictures say more than words
Peter
MyPlasmCNC
Machine Torch
Machine Torch
MyPlasmCNC
Machine Torch
Machine Torch
Looks like your happy with your setup, thanks for the feedback. When people have a problem it is not always the product.
I Run MyPlasmCNC on my STV table and the first installation of it was buggy and would reverse the parameters in the settings and cause similar issues to Maximusde34.
STV was quick to help send out an updated Install file and I did a complete reinstall of the computer application and it solved the parameter changing phenomenon.
Hi Peck thank for the reply the question I have do you use your table for any other function or only Plasma cutting.
At this point only plasma cutting.
- Joe Jones
That is some awesome artwork there! Wow! I wish I had the motivation to get into projects like that.
Franklin, KY., USA
Samson 510 & 4x4
CreatBot D600 PRO 3D Printer
12 Lasers
FREE DesignEdge Training!
Samson 510 & 4x4
12 Lasers
Thanks for the reply Peck, I thought that was the answer, to bad some limit the options with their product. As someone who has and uses my table for a multi-function tool, it is sad they put themselves in a small box. It seems with some small changes they could be open to more business/customers.
- Joe Jones
You can do a lot MORE than just plasma cutting with these tables. You just have to think OUTSIDE of the box!
Franklin, KY., USA
Samson 510 & 4x4
12 Lasers
Samson 510 & 4x4
12 Lasers
