Removing pause at beginning of cut.
I know this has been addressed before, but I couldn't find it with a search. When I load the G-code into Mach3 and select "Cycle Start", it runs through a few lines of code and pauses. I have to hit "Cycle Start" again for the cut to start. Where do I turn off the pause? Is it in the post processor or somewhere else in Sheetcam?
Re: Removing pause at beginning of cut.
There is a warnings setting at the top of the post processor.
It's not an error. It does it on purpose. Here is an example of the code:
N0010 (Filename: Beverly.tap)
N0020 (Post processor: CandCNCPlasma-rev11J.scpost)
N0030 (Date: 31/05/2019)
N0040 G20 (Units: Inches)
N0050 F1
N0060 G53 G90 G40
N0070 (Part: Beverly)
N0080 (Operation: Outside Offset, 0, T13: 65 amp 16g stainless steel)
N0090(Preset Volts: 124) (Preset AMPS: 65)
N0100 ( Air Pressure Preset: 75)
N0110 ( Soft Pierce : 60 percent )
N0120 (This code for use with Ether-Cut upgrade 12-19-14 or later)
N0130( Suggested Tip Size: 65 ) ( DTHC Delay: 1 sec )
N0140 ( Min Cut Length for DTHC ON : 1 units )
N0150 S900 (Global DTHC ON/OFF is ON )
N0160 S10 (Turn off DTHC at the beginning)
N0170 S3124 (Preset Volts set to 124 Volts)
N0180 S465
N0190 S875
N0200 S510 (DTHC Delay set to 1 Seconds)
N0210 S711 (DTHCIV tuning set to level 1)
N0220 S701 (Clear S Register)
N0230 M00
N0240(Paused: Check the DTHC Settings Hit RUN to continue)
N0050 F1
N0060 G53 G90 G40
N0180 S465
N0190 S875
N0230 M00
Yes, but you can disable the pause in the post if you want to.
Setting "warnings = false" all lower case will turn off the message and not pause . It there for the operator to confirm (and possibly override) the settings/parameters from the Toolsets .
I like it because sometimes, for whatever reason, the volts setting in Mach doesn't adjust to what is in the gcode. It becomes stuck on whatever it was set on and the only way I can get it to change is to restart Mach. If it weren't for the pause, I would have ruined many projects.
