Help with speed
Help with speed
I need some input, I fried my controller motherboard. I replaced it and got everything working correctly. 50/50 is spot on. One thing changed I cant figure out. My speed is faster then set. So I did a 25 inch square test at 100 ipm. It should take 60 seconds to cut it out at that speed. It is cutting it at 27 seconds. My gcode is correct so how can I slow it down?
Re: Help with speed
Are there dip switches on your new board that are not configured the same as the old board? Maybe steps per inch or something are off.
Re: Help with speed
Are those the screws on the stepper driver you adjust?
Re: Help with speed
Do you have the option of inch or MM that may not be set correctly
Re: Help with speed
I am not sure, I will have to try to find more options
