Another Magnetic Breakaway Torch Mount
Just figured I would show my version of a diy magnetic breakaway torch mount. All in all, with the magnets, aluminum drops, linear rails, and micro switches for the floating head I probably have about $50-$60 bucks in a floating torch head with a magnetic breakaway. It works great! It locates on the 4 domed bolt heads, which gave me some adjustment. With my last magnetic torch mount, I had it locate on bearings. Once it started getting junk behind it, there was some play in them. This way, I can make tiny adjustments to take the play out of it, and to get it cutting square.
Re: Another Magnetic Breakaway Torch Mount
Nice work thanks for posting, that's the first vertical table I have seen, how do you keep the water in
I bet he uses ice.
Hahaha I'm not sure why all of my pictures ended up sideways, but it does make it a little difficult to look at!
